Hi,
recently I've been experiencing link drops on the MoCA link between a pair of WF-803M units. They have been installed for about a year and are the only devices on the 'network'. Basically each one is directly connected to a coax point which feeds back to the attic, where there is a splitter joining them,
I've tried resetting them back to factory defaults and also tried upgrading from 1.0.6.0 to the 1.0.13.0 firmware.
I've tried to capture the status of the devices when the link drops and
SOC Version:MXL371x.1.18.7
My MoCA Version:2.5
Network MoCA Version:2.5
IP Address:<redacted>
MAC Address:<redacted>
Link Status:Down
Beacon Channel:1150
Primary Channel:1150
Secondary Channel:0
First Channel:1175
Number of Channels:5
Ethernet TX:
Tx Good: 0
Tx Bad: 0
Tx Dropped: 0
Ethernet RX:
Rx Good: 0
Rx Bad: 0
Rx Dropped: 0
When operating normally the Secondary channel is 1300
Link rates:
From/To 0 1
0 676 3456
1 3427 677
From/To 0 1
0 691 3531
1 3454 677
It is a bit tricky to capture both ends details as i loose connectivity to the far end. Is there any thing I could do to try debug this?
Kevin
MoCA drops may be caused by splitter, coax, or channel issues try MoCA-rated gear and channel lock. For fun, GamesPK App offers casino-style play.
Check your splitter and coax cables—signal issues may cause MoCA drops. A stable link ensures smooth play on Royal X Casino JazzCash casino app.
Why Cam **** Sites Remain a Top Adult Trend
Even after the pandemic, cam **** sites continue to thrive. This blog explores how real-time interaction, performer freedom, and audience intimacy keep these platforms hotter than ever.
I've tried to capture the status of the devices when the link drops and @ spanish dictionary
Anohter thing you can try is, connect the two MoCA adapters directly with a short coaxial cable. Check the link stability. If tlightroom premium mod apk 2025here is something wrong, Please send the faulty device to us. check lightroom premium mod apk 2025
Having trouble with your math assignments? Get professional math homework help, including step-by-step solutions. Get better scores by providing clear, concise explanations. Help with all math topics that are quick, dependable, and stress-free—increase your confidence now! Check out our online paraphrase tool!
yes, that is something I considered ,so have been sourcing a coax coupler as I don't have a route to add a new cable, but a simple "join" is about as simple as I can make things as part of the testing.
I'll report back once I have been able to investigate.
Kevin
Sorry, this device doesn't support monitoring protocol.
Anohter thing you can try is, connect the two MoCA adapters directly with a short coaxial cable. Check the link stability. If there is something wrong, Please send the faulty device to us.
If the two MoCA adapters can works well. Maybe we need to check the splitter and coaxial cable.
no, the only things besides the 2 bridge units are passive, cables, sockets, splitter, filter, termination resistors on spare splitter outputs etc.
I guess my next test would be to measure the continuity on the cabling and resistance, unfortunately I don't have any proper impedance measuring equipment nor anything to check frequency responses.
Do the units support any monitoring protocols like SNMP or is there a way to get something automatic out of the telnet interface? something to record signal levels etc.
thanks
Kevin
The MoCA link rate is good.
Do you have any other devices runing over the coaxial network?
For example, DOCSIS modem or other devices.
