I have two MA2500D devices connected via a dedicated RG6 coax cable roughly about 100ft long. No splitters. One MA2500D is connected to my ORBI RBR960 router and the other to my Apple TV 4K. I updated my MA2500Ds to the latest firmware. Everything works great except i get random drops of the Moca link. No set time or duration or event, just the Moca connection drops randomly. The Moca light is OFF and the ethernet light is On on both devices and i can't log into the user interface on either device in this state. If i remove and reconnect the ethernet connection on the router side or power cycle the MA2500D then the Moca link comes back and everything works properly. The devices can work for days and weeks or just an hour before i ge the random drop. I'm using the default settings.
The coax is prestine. I changed the connectors and measured the cable and it looks fine, no issues. It's almost like the Moca connection is going to sleep. There are no system or network settings on the AppleTV like on a PCs ethernet port to adjust.
I know other's have reported a similar situation but are there any tweaks or adjustments to work around this problem? There hasn't been any firmware updates from GoCoax in a long time and i can't believe this is a bug that's affecting everyone. Any Ideas?
Legacy Heating and Cooling specializes in top-quality Air Conditioning Installation for residential and commercial properties. With expert technicians and reliable service, Legacy Heating and Cooling ensures efficient cooling solutions tailored to your needs. Trust our team for professional installs that keep your space comfortable year-round in Vero Beach and surrounding areas.
Petey's HVAC is your trusted air conditioning contractor near me in Palatine IL, providing expert cooling solutions for residential and commercial needs. Our experienced team delivers fast, reliable service with a focus on energy efficiency and customer satisfaction. From installation to repair, Petey's HVAC ensures your comfort all year long with top-quality workmanship you can count on.
Keep your cooling system in peak condition with Advance Air, the trusted choice for homeowners seeking reliable AC maintenance company Hurricane UT. Our expert technicians ensure your air conditioner runs efficiently all season long. Whether it’s routine servicing or emergency support, Advance Air delivers comfort you can count on. Schedule your maintenance today with the top-rated local team!
Transform your space with expert bathroom remodeling Allen TXÂ services from Icon Remodeling Dallas. We deliver custom designs, high-quality finishes, and exceptional craftsmanship tailored to your needs. Whether you're planning a modern upgrade or a full renovation, our team ensures your bathroom is both stylish and functional.
I have also recently purchased 2 of these devices, checked latest firmware and have coax end to end. When they work they are fantastic, but mine also drop out every so often, Is there a way to retrieve logs off the boxes to help diagnose ?
Hi, could you check the MoCA link with the following steps?
• Select any MoCA adapter in the network.
• Set a fixed IP to your computer, such as 192.168.254.10. You can follow the guide to configure the fixed IP.
• Connect your computer to the LAN port of MoCA adapter via ethernet cable.
• Visit http://192.168.254.254, username is admin, password is gocoax.
• Go to the ‘MoCA Link rates’ page, make a screen capture and send it to us.
