  • Home
  • Products
    • WF-803M
    • MA2500D
  • Support
  • Forum
    • Members
  • More
    Use tab to navigate through the menu items.
    BUY NOW
    0CART
    • All Posts
    • My Posts
    goCoax-User
    Jul 02, 2021
    Network speed slower after v1.0.12 firmware upgrade
    in Everything for MoCA
    My MoCA network is significantly slower as compared to running on v1.0.6 firmware. At least, I think it is was the firmware upgrade that slowed everything down.
    Previously, when running v1.0.6, file transfer rates to/from my NAS were capped out at gigabit speed (~ 110 MB/s). My entire ethernet network (routers/switches) are gigabit.
    Now, transfer rates to/from any device (NAS, other PCs, etc.) over the MoCA network are capping out at ~ 40 MB/s.
    Direct ethernet connection (bypassing my MoCA network) also delivers gigabit speed, as expected.
    My slowest MoCA link rate between my 3 goCoax devices is 3366 Mbits/sec, which is the rate its always shown and is healthy for MoCA 2.5 nodes.
    MoCA 2.5 iperf3 test:
    PS C:\Downloads\iperf-3.1.3-win64> .\iperf3.exe -c 10.1.1.241 -p 5201
    Connecting to host 10.1.1.241, port 5201
    [ 4] local 10.1.1.100 port 54203 connected to 10.1.1.241 port 5201
    [ ID] Interval Transfer Bandwidth
    [ 4] 0.00-1.00 sec 38.9 MBytes 325 Mbits/sec
    [ 4] 1.00-2.00 sec 40.4 MBytes 339 Mbits/sec
    [ 4] 2.00-3.00 sec 40.8 MBytes 342 Mbits/sec
    [ 4] 3.00-4.00 sec 40.6 MBytes 341 Mbits/sec
    [ 4] 4.00-5.00 sec 40.2 MBytes 337 Mbits/sec
    [ 4] 5.00-6.00 sec 40.8 MBytes 342 Mbits/sec
    [ 4] 6.00-7.00 sec 40.1 MBytes 337 Mbits/sec
    [ 4] 8.00-9.00 sec 40.0 MBytes 335 Mbits/sec
    [ 4] 9.00-10.00 sec 40.8 MBytes 341 Mbits/sec
    [ 4] 0.00-10.00 sec 401 MBytes 336 Mbits/sec sender
    [ 4] 0.00-10.00 sec 401 MBytes 336 Mbits/sec receiver
    Gigabit ethernet (cat5e) iperf3 test:
    [ 4] local 10.1.1.100 port 64911 connected to 10.1.1.241 port 5201
    [ 4] 0.00-1.00 sec 112 MBytes 938 Mbits/sec
    [ 4] 1.00-2.00 sec 112 MBytes 939 Mbits/sec
    [ 4] 2.00-3.00 sec 112 MBytes 936 Mbits/sec
    [ 4] 3.00-4.00 sec 113 MBytes 945 Mbits/sec
    [ 4] 4.00-5.00 sec 113 MBytes 945 Mbits/sec
    [ 4] 5.00-6.00 sec 112 MBytes 937 Mbits/sec
    [ 4] 6.00-7.00 sec 112 MBytes 942 Mbits/sec
    [ 4] 7.00-8.00 sec 113 MBytes 945 Mbits/sec
    [ 4] 8.00-9.00 sec 113 MBytes 947 Mbits/sec
    [ 4] 9.00-10.00 sec 112 MBytes 941 Mbits/sec
    [ 4] 0.00-10.00 sec 1.10 GBytes 942 Mbits/sec sender
    [ 4] 0.00-10.00 sec 1.10 GBytes 942 Mbits/sec receiver
    I know that iperf isn't always the perfect test, and I know about passing in -w 2M, which seems to improve things significantly. However, the rates above reflect my real-world transfer speeds to/from my NAS perfectly.
    Now, I can't be 100% sure that v1.0.12 is the cause of the performance drop, because I did not perform the iperf tests on v1.0.6 before upgrading, and I only noticed my network speeds were slow a few weeks after upgrading. I also had an issue with my NAS (dead motherboard) that caused it to be offline for about a week during the same timeframe. That all said, I can't think of any other cause. I know for a fact that when I first set up the MoCA network (with the v1.0.6 firmware that shipped on the goCoax units) that I was getting ~ 110 MB/s for months, because I've transferred several terabytes of data and I've always seen capped gigabit rates previously.
    I'm seeking advice on how to investigate this further and remedy the speed issue. Nothing else has changed physically. I am using high quality and short coax cables (https://www.amazon.com/gp/product/B00DI88YR2), high quality and short CAT7 ethernet cables (https://www.amazon.com/gp/product/B08541KP7K), and a high quality MoCA compliant splitter (https://www.amazon.com/gp/product/B01552LYL6).
    Finally, the goCoax units show backup firmware of the original v1.0.6 image. Is it possible to revert to the backup image? I couldn't find instructions on how to do this, and I am not sure a factory reset accomplishes this.
    1 answer0 replies
    0
    1 Comment
    Share Your ThoughtsSign up to leave a comment.
    G
    goCoax
    Jul 03, 2021
    To revert the backup image. Please try these steps:
    1, Power off the device
    2, Press the reset button
    3, Power on the device
    4, Wait for about 10s, release the reset button.
    We don't think the lower rate is related to the new firmware. Anyway, please try to revert and check again.
    If you need any other support, please let us know.
    1
    1 comments
    Similar Posts
    • Is there any advantage for upgrading firmware to​ v1.0.12 from v1.0.6 for WF-803M, other than supporting TR-069, in a home setting?
    • After ​v1.0.12 firmware - No WebGui and no IP addr.
    • Unmanaged network switch keeps dropping moca speed to 100mbps.
    ABOUT US
    Every home is unique and needs best home networks. At goCoax, we believe in MoCA equipment that is simple to install and provides maximum performance - no matter what kind of home we're in.
    Subscribe today to receive promotional offers, new release info and more!
    • Black Facebook Icon
    • Black Twitter Icon
    15902A Halliburton Rd #662 Hacienda Heights, CA 91745, USA
    © 2021 by goCoax
