Got 2 MA2500C adapters on Amazon.
They were working fine for 1 day, then 20-min long connection drops started to appear every 2-4 hours.
I tried updating first adapter to 3.0.5 in hopes that it will fix drops – waited for 5 minutes – got same problem as here.
Thankfully, this got healed after reset. Version didn't update though, still 3.0.4. So no way to update the device.
Again, in hopes to heal drops – I've tried resetting second adapter – now it doesn't work after reset. Just boots, quickly blinks with ETH, then in 1 sec quickly blinks with MoCA, then reboots and everything goes again. ETH connection to it quickly appears and drops every time it reboots.
So for now I've connected the first adapter (that failed to update) to an old MoCA modem Actiontec mi424wr. Work flawlessly, but not as fast (160mb tops) because modem is old.
Second device is still broken though.
It sounds like you’re facing frustrating issues with your MA2500C adapters, especially after trying to reset or update them. This is similar to checking your SASSA check status check—you expect a straightforward update or confirmation, but glitches and inconsistencies can make the process unreliable. If one adapter now works with your older modem, at least you’ve found a temporary solution.
The city's lock-making hub employs thousands, producing a wide range padlock manufacturer in aligarh mortise locks, and advanced security systems for domestic and international markets.
For the faulty device, could you try the following steps to recover?
1, Press the reset button.
2, Power on the device
3, Wait for at least 10 seconds
4, Release the reset button.
If you still have any issue, please let us know.
