I recently purchased the MoCA 2.5 MA2500D.
The truth is that I am very happy with its performance.
Now, currently I only send ethernet to the antenna socket of a room, but I would like to know what I have to do to also watch TV in that room.
Can you tell me what steps I have to follow, what connections I have to make and what components I have to acquire?I have my own antenna with a single cable (IN) that comes down from the mast and a distributor with 6 OUT sockets.
Thank you very much for your help.
Polytechnic courses after 12th are a great option for students who want to gain practical skills and enter the workforce quickly. These courses offer a wide range of specializations like engineering, computer science, and design, making them ideal for those looking for job-oriented education without investing several years in traditional degrees.
I have already solved.
Luckily I didn't have to wait for you guys to answer me...
Hi
Do you mean satellite antenna or normal air anttenna?
If satellite, sorry, MoCA and Satellite singal can't share the same coaixal network.
If normal air antenna, sure, you can use them together in the same coaxial network.
You just need input your antenna signal into your coaxial network, for example, connect it to the splitter. In the room, you need to install a two-way splitter. input is connected to the RF outlet on the wall. One output is for MoCA adapter. Another output is for TV.
If you can draw a simple network diagram, that will help us to understand your requirment more clearly.
