Hi,
I live in an appartement. The internet and TV signal is attached via cable.
Unfortunatelly I see a lot of pixel issues / artefacts in TV signal once MoCa network is running.
Any help for that?
I use 2x goCoax MA2500D and the official SP-2 splitter and the PoE filter from the same package.
Below you can see my installation path:
The internet modem/router (AVM Cable 6600) uses DOCSIS3.1. Due to that I have installed the recommended PoE filter based on the description from here:
Every 1-2 seconds I see artefacts in TV signal. It is somehow matched to the traffic ethernet LED on the goCoax device.
Best Regards
Pixelation with MoCA setups can often be fixed by checking splitter quality, PoE filter placement, or coax terminations. Sometimes just swapping cables helps too.
In moments like these, I find calm in reciting سورة الواقعة—it reminds me that patience and clarity go hand in hand, even with tech glitches. Hope your setup gets smooth soon!
Watching TV with annoying artifacts can really kill the experience, especially when streaming live sports or shows on mobile devices. Since my internet connection felt unstable, I looked at https://cricket-wireless.pissedconsumer.com/review.html where users talked about how their network coverage and data plans impacted streaming quality. Those insights highlighted the importance of strong signal strength and choosing the right plan for smooth video playback. Taking this advice helped me upgrade my mobile service and improve streaming without constant buffering or glitches.
Did another check.
Enabling Ext-Band was possible if I have reduced the Tx rate from 10 to 8 on the adapter near the TV.
Unfortunately the network speed was much lower (avg. 50 mbit/s).
So far disabled ext Band with full Tx rate is the best solution and provides avg. 550 mbit/s.
Update:
I have tested my old TV (Samsung 55" KS7090) on the same wall outlet with the same cable: no issues at all.
Tested again with my current TV (Samsung 65" QN90A): again artefacts.
So obviously the current TV seems to be more sensitive.
Any recommendations to fix that on the current TV?
