Hi there,
I have 3 Asus AIMesh nodes all connected to MA2500D units for wired backhaul. However, one of the nodes keeps getting disconnected and as part of my troubleshooting, I'm trying to determine if I need to give LAN IP addresses to the MoCa devices or leave them with the factory configuration.
Any thoughts?
Setting up a wired backhaul for AI Mesh sounded simple, but the IP conflicts turned it into a mess. Tried troubleshooting on my own, but nothing seemed to fix the issue. It reminded me of when I had to deal with securus technologies customer service for a completely different tech problem. Took a while to get a clear answer, but eventually, I got the information I needed. Sometimes, no matter how much research you do, you still end up needing support to get things working properly.
No neeed to set fixed IP to MoCA adapters.
Could you check the MoCA link rate from the webpage of MA2500D?
You can following these steps:
• Select any MoCA adapter in the network.
• Set a fixed IP to your computer, such as 192.168.254.10. You can follow the guide to configure the fixed IP. Here are the guidelines for windows or Macbook.
• Connect your computer to the LAN port of MoCA adapter via ethernet cable.
• Visit http://192.168.254.254, username is admin, password is gocoax.
• Go to the ‘MoCA Link rates’ page, make a screen capture and send it to us.
Normally, the link rate should be about 3500Mbps.
